Problems with my GPU
JzMcqueen
9
Hi i have an R9 270 OC and I've installed the latest drivers for it but when i go select it in screen resolution under the 'Display' drop down box it thinks i'm trying to add an additional screen i think? any suggestions? thanks.
https://imgur.com/a/Exajj
Specs
GA-78lmt-usb3
R9 270 OC powercolor
12GB DDR3 Hyperx Fury
amd phenom ii x4 965 black edition
That dropdown box shows you that you have a c24f390 display hooked up to an amd r9 series card. That is all as it should be. To change resolution, choose the next box down that says resolution.
If you had multiple displays attached, you would choose the monitor you wanted to edit from the display drop down first, then alter it's resolution with the resolution drop down.
Thanks i still get the performance from my GPU in game but i can't up my resolution.
If you want to change resolution in game, you need a monitor capable of handling that resolution, and you would make that change in the game, not in windows display settings. Windows display settings is for windows and the way it appears. Games resize according to the settings in the game itself, but only if you can support that resolution.
