Question Problems with New Build
Mike12944
Commendable
Dec 1, 2019
11
I've posted this in other places but to no avail. Hoping someone here could point me in the right direction. Thanks.
So I just built my new computer and my 3080 has shut off 3 times now in two days. Two times while playing a game and another while I was on my desktop. I don’t believe it’s due to heat. The temp was around 78 one time in the game and 81 the second. When I was on my desktop it was 55. Everything else was still running the game continued on but of course I could not see the screen. A guess of mine and I’m just guessing is maybe power. I have a Corsair rmx1000 watt PSU,I have 5 fans on the case, a Corsair iCUE H150i, Intel 12700KF and then my 3080. When I looked at the device manager it says Windows has stopped this device because it has reported problems. It is running now. I also have an error now with my HD Audio Controller. I do have an update pending that just came up. I did just enable windows sonic for headphones. So I’m guessing that’s why that came up. After it happened the first two times I then updated my BIOS. I also made sure the graphics card was seated in the slot and it is. Just really at a loss. Really hoping the card isn’t shot. Any suggestions where to start looking? Thanks.
I have looked at the event logs and these are what I found that showed up right before my graphics card shut off.
Event ID 9027
The Desktop Window Manager has registered the session port.
Event ID 1000
Faulting application name: dwm.exe, version: 10.0.19041.746, time stamp: 0x6be51595
Faulting module name: KERNELBASE.dll, version: 10.0.19041.1741, time stamp: 0xe9b4a91b
Exception code: 0xe0464645
Fault offset: 0x000000000010fa32
Faulting process id: 0x1c40
Faulting application start time: 0x01d88f1664fe69f4
Faulting application path: C:\Windows\system32\dwm.exe
Faulting module path: C:\Windows\System32\KERNELBASE.dll
Report Id: c15b7985-311f-411a-8297-18e54724461a
Faulting package full name:
Faulting package-relative application ID:
Event ID 1001
Fault bucket , type 0
Event Name: LiveKernelEvent
Response: Not available
Cab Id: 0
Problem signature:
P1: 141
P2: ffff8109dc544460
P3: fffff8032b6204d0
P4: 0
P5: 1674
P6: 10_0_19044
P7: 0_0
P8: 768_1
P9:
P10:
\\?\C:\Windows\LiveKernelReports\WATCHDOG\WATCHDOG-20220703-1452.dmp
\\?\C:\Windows\TEMP\WER-2890843-0.sysdata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER2729.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER272A.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER272B.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER273C.tmp.txt
These files may be available here:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Kernel_141_c7201f7a9f9fd2742e37ef1ac2ba49cc11ed4_00000000_f0290a45-9ac4-4ab0-9589-f4cbc78837e0
Analysis symbol:
Rechecking for solution: 0
Report Id: f0290a45-9ac4-4ab0-9589-f4cbc78837e0
Report Status: 4
Hashed bucket:
Cab Guid: 0
Event ID 0
The Desktop Window Manager process has exited. (Process exit code: 0xe0464645, Restart count: 1, Primary display device ID: NVIDIA GeForce RTX 3080)
I'm having a similar issue with my 3080 I can't even get windows installed I'm running A RMX 850 suspect it's a power issue. But your running a 1000w which I just ordered from amazon so now I'm thinking it might not be a power issue
