Problems with OBS
armandbig33
Commendable
Apr 14, 2016
16
Hello.
I recently downloaded OBS to record some game footage...... Minecraft, Star wars battlefront 2 and so on.... . I have no idea why nothing works. I have EVERYTHING in the settings setup right but when I try to record it either gets pushed into a far corner or it's a blanc screen sometimes it gets pushed into a corner and stays there frozen or sometimes it just freezes. I AM DESPERATE!
I tried everything from uninstalling OBS and installing it again to resetting settings and doing it all over again.
My pc should be able to handle it and I don't know what the problem i.
Please help me I am willing to cooperate at everything and I will add a Log file since it only comes to mind after I wrote all of this.... so thanks in advance.
15:18:04.622: CPU Name: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
15:18:04.622: CPU Speed: 4008MHz
15:18:04.622: Physical Cores: 4, Logical Cores: 8
15:18:04.622: Physical Memory: 16345MB Total, 12641MB Free
15:18:04.622: Windows Version: 6.1 Build 7601 (revision: 24000; 64-bit)
15:18:04.622: Running as administrator: true
15:18:04.622: Aero is Enabled
15:18:04.623: Portable mode: false
15:18:04.694: OBS 21.0.1 (64bit, windows)
15:18:04.694: ---------------------------------
15:18:04.718: ---------------------------------
15:18:04.718: audio settings reset:
15:18:04.718: samples per sec: 44100
15:18:04.718: speakers: 2
15:18:04.744: ---------------------------------
15:18:04.744: Initializing D3D11...
15:18:04.744: Available Video Adapters:
15:18:04.746: Adapter 1: NVIDIA GeForce GTX 1060 6GB
15:18:04.746: Dedicated VRAM: 2034958336
15:18:04.746: Shared VRAM: 4006311936
15:18:04.746: output 1: pos={0, 0}, size={1920, 1080}, attached=true
15:18:04.748: Loading up D3D11 on adapter NVIDIA GeForce GTX 1060 6GB (0)
15:18:04.770: D3D11 loaded successfully, feature level used: 45056
15:18:05.496: ---------------------------------
15:18:05.496: video settings reset:
15:18:05.496: base resolution: 1920x1080
15:18:05.496: output resolution: 1920x1080
15:18:05.496: downscale filter: Lanczos
15:18:05.496: fps: 60/1
15:18:05.496: format: NV12
15:18:05.505: Audio monitoring device:
15:18:05.505: name: Standard
15:18:05.505: id: default
15:18:05.505: ---------------------------------
15:18:05.549: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
15:18:05.582: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
15:18:05.673: [AMF] <obs_module_load> AMF not supported (no AMD graphics)
15:18:05.673: Failed to initialize module 'enc-amf.dll'
15:18:06.088: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
15:18:06.100: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
15:18:06.140: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
15:18:06.166: Failed to load 'en-US' text for module: 'obs-browser.dll'
15:18:06.166: [browser_source: 'Version: 1.29.0']
15:18:06.488: NVENC supported
15:18:07.072: VLC found, VLC video source enabled
15:18:07.138: No blackmagic support
15:18:07.230: [Media Foundation encoder]: plugin is disabled for performance reasons on Windows versions prior to 8
15:18:07.267: ---------------------------------
15:18:07.267: Loaded Modules:
15:18:07.267: win-wasapi.dll
15:18:07.267: win-mf.dll
15:18:07.267: win-dshow.dll
15:18:07.267: win-decklink.dll
15:18:07.267: win-capture.dll
15:18:07.267: vlc-video.dll
15:18:07.267: text-freetype2.dll
15:18:07.267: rtmp-services.dll
15:18:07.267: obs-x264.dll
15:18:07.267: obs-vst.dll
15:18:07.267: obs-transitions.dll
15:18:07.267: obs-text.dll
15:18:07.267: obs-qsv11.dll
15:18:07.267: obs-outputs.dll
15:18:07.267: obs-filters.dll
15:18:07.267: obs-ffmpeg.dll
15:18:07.267: obs-browser.dll
15:18:07.267: image-source.dll
15:18:07.267: frontend-tools.dll
15:18:07.267: enc-amf.dll
15:18:07.267: coreaudio-encoder.dll
15:18:07.301: ==== Startup complete ===============================================
15:18:07.302: Service '' not found
15:18:07.319: All scene data cleared
15:18:07.319: ------------------------------------------------
15:18:07.400: WASAPI: Device 'SONY TV (NVIDIA High Definition Audio)' initialized
15:18:07.460: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
15:18:07.547: Switched to scene 'Szene'
15:18:07.547: ------------------------------------------------
15:18:07.547: Loaded scenes:
15:18:07.547: - scene 'Szene':
15:18:07.547: - source: 'Spielaufnahme' (game_capture)
15:18:28.699: [game-capture: 'Spielaufnahme'] attempting to hook fullscreen process: javaw.exe
15:18:28.700: [game-capture: 'Spielaufnahme'] using helper (compatibility hook)
15:18:28.705: [game-capture: 'Spielaufnahme'] hook not loaded yet, retrying..
15:18:31.715: [game-capture: 'Spielaufnahme'] attempting to hook fullscreen process: javaw.exe
15:18:31.746: [game-capture: 'Spielaufnahme'] gl shared texture capture successful
15:18:31.749: [game-capture: 'Spielaufnahme'] shared texture capture successful
15:18:35.726: [game-capture: 'Spielaufnahme'] Hooked DXGI
15:18:46.512: [game-capture: 'Spielaufnahme'] capture window no longer exists, terminating capture
15:18:46.512: [game-capture: 'Spielaufnahme'] capture stopped
15:19:13.800: [game-capture: 'Spielaufnahme'] attempting to hook fullscreen process: javaw.exe
15:19:13.817: [game-capture: 'Spielaufnahme'] shared texture capture successful
15:19:18.471: Starting recording due to hotkey
15:19:18.472: ---------------------------------
15:19:18.487: [NVENC encoder: 'recording_h264'] settings:
15:19:18.487: rate_control: CBR
15:19:18.487: bitrate: 20000
15:19:18.487: cqp: 0
15:19:18.487: keyint: 250
15:19:18.487: preset: default
15:19:18.487: profile: main
15:19:18.487: level: auto
15:19:18.487: width: 1920
15:19:18.487: height: 1080
15:19:18.487: 2-pass: true
15:19:18.487: b-frames: 2
15:19:18.487: GPU: 0
15:19:18.487:
15:19:18.826: ---------------------------------
15:19:18.826: [FFmpeg aac encoder: 'Track1'] bitrate: 320, channels: 2, channel_layout: 3
15:19:18.826:
15:19:18.876: ==== Recording Start ===============================================
15:19:18.877: [ffmpeg muxer: 'adv_file_output'] Writing file 'G:/obs/Videos/2018-01-24 15-19-18.mp4'...
15:19:43.732: adding 46 milliseconds of audio buffering, total audio buffering is now 92 milliseconds
15:19:48.070: Stopping recording due to hotkey
15:19:48.388: [ffmpeg muxer: 'adv_file_output'] Output of file 'G:/obs/Videos/2018-01-24 15-19-18.mp4' stopped
15:19:48.388: Output 'adv_file_output': stopping
15:19:48.388: Output 'adv_file_output': Total frames output: 1756
15:19:48.388: Output 'adv_file_output': Total drawn frames: 1763 (1771 attempted)
15:19:48.388: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 8 (0.5%)
15:19:48.388: ==== Recording Stop ================================================
15:19:48.801: [game-capture: 'Spielaufnahme'] capture window no longer exists, terminating capture
15:19:48.801: [game-capture: 'Spielaufnahme'] capture stopped
