Problems with Philips monitor!
darian2hunter
199
This problem is really annoying and i could probably fix it if i knew what the issue was called but, when most of the screen is dark, it takes 1 or 2 seconds for the screen to dim down, and when it is something bright, it does the same?
I tried disabling the smart monitor feature but it is still happening can you please help?
The "blue" connector is VGA. DVI is usually white.
This sounds pretty old, and the backlight sounds like it is starting to go. Probably due for an upgrade.
