[SOLVED] Problems with port forwarding.
Jun 12, 2020
Good afternoon everyone. I changed the router a few days ago, and I'm having trouble opening the doors. I want to open the doors to be able to play Warzone with less lag.
I've already followed all the tutorials I found, but I'm having difficulties. I already put my computer on iPv4 static ip, 192.168.1.x.
I have a TL-WR845N router and an Arris modem. On the router I have already forwarded all the ports to my computer's IPv4 ip, 192.168.1.x.
https://ibb.co/6wW4DL6
My problem is in the settings on the modem.
I access the modem through the Default Gateway on the router's WaN, 192.168.0.1.
https://ibb.co/TtXfJ30
When forwarding on the modem, my machine's 192.168.1.x ip is not accepted. The only IP that I was able to use is the IP that in my router's Wan is marked as Default Gateway. In this case, the same IP that I used to access the modem.
https://ibb.co/r6PgNQv
Even after these actions the test continues to show that the doors are closed. What am I doing wrong?
https://ibb.co/0qSB6QS
I appreciate any help.
You best option is to run as just a modem and disable the router part. Trying to get port forwarding though 2 routers is a pain.
If you really want to run 2 router you need to forward to the IP assigned to the wan port of the second router
The second router should show it. This is hard to say it is not consistent between routers. You are just going to have to look around some it is a status screen and some have a wan port sceeen
Thx for the tip, I found the IP. and I managed to open the doors. It didn't solve my NAT connection problem in the game, but it was worth the try.
