I 'm using TP-Link TL_PA511 V1 Powerline Adapters and when I plug both adapters directly into the single wall socket, all three leds are turned on and device work fine. ADSL router is linked to 1st adapter while a computer is linked to the 2nd one.
If I unplug ethernet cable from 1st or 2nd pwl adapter after undefinded minutes, all 3 leds are turned off of corresponding adapater; this behaviour happens with both devices.
TEST A: If I link again ethernet cable to 1st adapter , It happens nothing and state of device is alwways the same state (3 led turned off).
I read that if there is no activity, powerline adapter goes into power-save mode with power led which is blinking, but I see all 3 led turned off !
Can you suggest me other test? What do you think?
They are damaged ?
They are damaged ?
