Problems with Samsung Galaxy Y Duos (GT-S6102)
SteenZF
Commendable
Apr 20, 2016
18
I have been having problems with my Samsung Galaxy Y Duos (GT-S6102). The issue is that I can't or the phone can't mount any MicroSD cards. I would only like a solution that does not include physical tampering with any of the parts apart from the MicroSD card. Thanks in advance.
If it does not see any of the cards, and those cards work fine in a computer or another phone, you may just have a broken SD card slot. Did you try rebooting the phone and see if it sees the card then?
Did some testing and found out that the MicroSD card didn't work on mobile phones but did work on laptops and the like. It must have been partially broken or something like that. Thanks anyway!
