Ok, first of all it was a pain in the rear to install.
NONE of the drivers at creative worked, not even LW3.0 (which has a big SUCKS tag on the installation program btw, see the end remark).
I called the shop were i bought and they said "Aparently, there has been some problems with SB Live 5.1 and the new drivers or the LW3.0, please run the setup instalation on the bundled CD. You might run into some trobles though, but they're easy to handle, just call again if you can't sort them out" (i know, but it was a friend of mine that works at the shop).
So i did, i ran the setup on the CD and this time the drivers were installed.... NOT... they were installed but main driver had the BIG Yellow sign on it. Called the shop again. "Yeah yeah, we've been having the same problem here too, just click on the "Update drivers" button and use the drivers on the CD... that should work!"
Suprise it did work (my apreciation for Creative's products has dropped to a negative 20 points by now)!!! Well i have sound and everything but the "Creative GamePort Device" now has a the yellow sign!!!
The board is an Asus A7V133 without the onboard sound system and i disabled the AC'97 Sound Codec on the bios (which in fact doesn't exists on the board, 'twas just to be safe), and nothing, and i can't solve it, neither my friend at the shop!
I've asked creative on this... but, suprise, no reply (another negative 10 points hit, we're now at -30 points).
Can anybody help me at this?
END NOTE:
Just for the fun of it, a friend of mine couln't install the LiveWare 3.0 because it sayd he didn't had enough free space (he had like, 7gigs free), so he asked Creative on this... the reply? "Save all your documents and reformat the disk and install windows" .
What kind of answer was that (another -20 points to creative)... but my friend did what was asked, and solved........NOTHING... same problem with the fresh instalation of windows... another mail to Creative ... reply "Remove your NIC card and try again" (ANOTHER -1000 points since nothing has the do with it, since the card is working swell, he just can't install LiveWare3.0 'cause it says he doesn't have enough free space).
Really i have a TnT2Ultra from Creative and had a AWE32 and i had a major GOOD impression on Creative. Now i've downloaded the new drivers for Win98SE for the TnT2Ultra and windows crashes after 5 minutes..... What kind of BABOONS are running Creative these days???
END NOTE:
