Problems with Sending (2)
Jerry
1,812
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
Ever since I installed SP2 I have been unable to start Winfax 10
So I thought i'd try Xp Fax. When I first configured it I could send,
got a handshacking screech and then"error unable to send fax" or
something to that effect (I didn't write it down)
I was also unable to"pause" the fax within the console
I rebooted and now when I use the Wizard it goes thru' to the eend and
nothing. No send. Nothing in the monitor. Nothing in the Console
What gives?
Using a standard PCI US Robotics WinModem w/voice. i have broadband
(but obvously tried it not connected). Running XpPro SP2
What gives? Any help appreciated.
Jerry
Hi,
I have the same problem. Windows fax failed to work after installation
of SP2. It still doesn't work after uninstallation. Still struggling..
KC
> What gives?
> Jerry
Jerry & KC: Any luck yet? Any answers from Microsoft on a fix for this? I
had no trouble with faxing prior to the SP 2!
G
"KC" wrote:
> Hi,
> KC
> > What gives?
> > Jerry
Can you please open Control Panel | Phone and Modem Options and see if any
Default Location is selected (alternately, you can do start | run |
telephon.cpl to invoke the same UI). If not default location is selected,
please select one. Let us know if this fixes your problem.
Thanks,
Anand
Ananda Sarkar
Microsoft Printing, Imaging and Fax Team
This posting is provided "AS IS" with no warranties, and confers no rights.
Please do not send email directly to this alias. This alias is for newsgroup
purposes only.
"G" <G@discussions.microsoft.com> wrote in message
news:4D6E42FD-FD59-4F23-BD67-5F7C2593AA2D@microsoft.com...
I
> G
> "KC" wrote:
> > Hi,
installation
> > KC
> > > What gives?
> > > Jerry
It is working now...I am a bit embarrassed to say, but I think the phone line
into the jack was loose (tab is broken). I have no problems sending and, I
assume (because I have not tried), receiving.
G
> Thanks,
> Anand
> Ananda Sarkar
> purposes only.
> I
> > G
> > "KC" wrote:
> > > Hi,
> installation
> > > KC
> > > > What gives?
> > > > Jerry
Latest posts
