Hello!
When I'm trying to start PC, coolers start spinning for 1 second, then they stop for 2-3 second, and start spinning again and PC turns ON. After this it throws me to "American Megatrends" screen and shows next message:
What did I try:
Motherboard: ASUS Prime Z270-A
CPU: Intel Core i5-7600 Kaby Lake
Memory: Corsair Vengeance LPX 16GB DDR4 2400MHz
Storage: Corsair Force MP500 NVMe SSD M.2 240GB + Samsung SSD 860 EVO 250 GB
Video Card: EVGA GeForce GTX 1060 Gaming ACX 3.0 6.0 GB
Power Supply: EVGA ATX 600 Watt
SMART Status for M2 SSD:
Does it mean that my SSD is dying?
After pressing F1 I get into BIOS. I change nothing and run PC and it works. But it knocks the clock and date settings. If I will reboot PC (without unplug power) there will be no errors. Also I noticed that CPU_LED has red light (when coolers start spinning for 1 second and then stop).Please enter setup to recover BIOS setting.
After setting up Intil(R) Opane Memory or the RAID configuration was built.
SATA Mode Selection must be changed to RAID mode to avoid unknown issues.
Press F1 to Run SETUP
What did I try:
- Set DEFAULT BIOS settings;
- Replace CMOS battery;
- Set "Launch CSM" to enabled;
- Remove M2 SSD - and it starts on the first try (but cannot boot, because no OS on SATA SSD).
