So I suppose some of this is my own fault so I’ll start with the first issue. So I had a cooling leak which hit my mobo pretty bad shut it off very fast and dried all with isopropyl re assembled and worked again flawlessly for another month. One morning I came down and everything was running but black screen so tried to reboot and was stuck on cpu debug led so I thought ok maybe the liquid leak was worse than thought. So I replaced mobo,cpu,psu and upon inspection of the old board I found that under the vrm heat sincs it was still very wet and on the back of the board there was some resistors burnt out at the back of the vrm section. Ok my fault so I’ve assembled all the new components and worked for a few days but with constant bsod ran memtest86 first time 10 errors ran windows mem diagnostic and had errors I updated bios to latest and now I can’t get it to post, all switches on fine leds fans I get a brief signal to my screen which is black but it’s still a signal then cpu debug lights up and I lose power to keyboard and mouse. So a question did the old mobo kill all 4 sticks of ram in that incident as the only two components left to replace is gpu and ram specs as follows Msi x470 gaming pro carbon. Ryzen 7 2700. Corsair rm 1000x. Amd sapphire nitro r9 390. Corsair vengeance 32gb x4 8 gig sticks. Case raijintek enyo showcase. I’m really at a stuck point oh and to add before the no post it kept corrupting windows media player files (I use this pc for music) so that’s important to me. I can’t find the dump files as I can’t boot it but I remember the word kernel if that helps? I’m on my mobile and hope I posted this in the right place with enough info thanks again as I’m really pulling my hair out kn this one now
