Problems with tv card
Kenia
Hello:
I've recently got a tv card model Instant tv dvs-s PCI Ads Tech to use it in my PC. I've been trying to use the software contained in the installation Cd, but I just don't get any channel signal, so I can see nothing. I also tried with a software named MiTheatre or MyTheatre and it's also been helpless. So if someone knows where I can download the crack of any software that makes the kind of card I'm using work properly or either what I can do (a plugin to install maybe) to use MyTheatre, I would really appreciate any help. Thanks
Hello, you will definetely have to post more details. Your system, what kind of card it is when it was made etc. Is the company still around? Have you been able to go to their website to grab updated drivers? Do those things, if there is no support for it then I would say you will probably have to buy a new card from a better company.
ok first of all did ya do the country settings right ntsc and so forth and did ya do the channel scan for it to detect the channels if not check these things
