G
Guest
Guest
Archived from groups: alt.internet.wireless (More info?)
Greetings -
I've been happily using my LinkSys 802.11b wireless router (BEFW11S4),
with my laptop (running WinXP SP1), which has a WPC11 v4 wireless card
- but, using WEP encryption.
Fora bunch of reasons (most having to do with a desire to increase my
system security), I decided to try 'upgrading' to WPA (using PSK).
However, I've had no luck at all - if I set up the router for DHCP, my
laptop doesn't pick up an IP number. If I try a fixed IP address, I
can connect to the router, but I can't get out to the internet.
I've done all the usual things (upgrade drivers, confirm WPA patch for
WinXP installed, etc), but no luck.
What I find really puzzling is that WEP works perfectly. I've followed
the WPA instructions step for step, based on a lot of articles I've
read, and yet I'm still having no luck with it.
I'm guessing this is a fairly common problem, and am hoping there are
some common fixes out there.
Suggestions?
Greetings -
Suggestions?
