alsmith39
7
It as only started doing this recently it is a cd grive but will not install new programs
Yes, the same thing will happen. If you are in VLC, you need to select on that video_ts folder and play that file.
To set up an autorun default, right click and go to the properties of the CD drive in my computer. On the autoplay tab, you can set default actions for each type of media.
