G
Guest
Guest
Hey all!
I just put in a Creative Labs DXR2 dedicated DVD decoder card. Installed the software and tried to run a DVD.
When I do I get the following error:
WARNING!
DVD ROM does not support copyrighted DVD's. Continuing may halt your system.
Continue?
I hit yes.
Then:
Encore DVD cannot play. DVD ROM does not support copyrighted material.
And it refuses to play (obviously). Ok. My friend used this same card on a creative labs DVD -ROm. Is i just something as simple as the DXR2 simply needs a Creative DVD-ROM to be fully functional? My Dvd-ROM is a 10X Afreey drive. Model DD-4010E. Using any software DVD decoder everything works fine.
Any help would be appreciated.
System specs:
AMD T-Bird @ 850
ABIT KT7
256MB Pc133 Cas2
Afreey 10X DVD-rom DD-4010E
Hercules 4500 Kyro2 video card AGP 64MB
Win98 SE
Thanks
"This is my Kyro 2, with which I am well pleased."
The Jolly Wizened Oaf!
WARNING!
Continue?
I hit yes.
Then:
System specs:
AMD T-Bird @ 850
ABIT KT7
256MB Pc133 Cas2
Win98 SE
Thanks
