I've been going through threads on this site for years now but I've never had to make a post until now. It might be a bit of a long read but any help is appreciated! Please do tell me if I've been misinformed at any point. Anyway, here goes:
I'm building a new computer and I had pretty much settled on which components I was going to get, most importantly an Intel Core i5 4690K Processor and 2x8GB 2400MHz DDR3 RAM. This was fine, and I had found a motherboard which could take both, but after more research I found out that the 4690k only accepts RAM up to 1600MHz, and that any higher RAM speeds won't be used. I read some more threads here from what I've gathered the CPU can be changed in the BIOS, but this technically counts as overclocking. I am adverse to overclocking as it supposedly significantly shortens the lifespan of the components and I'm looking to futureproof this PC as much as possible in my budget (and I am splashing out), but there was some debate in the threads as whether changing the settings in the BIOS actually counted as overclocking.
If doing this won't negatively affect my computer in anyway then that's fine, my problem ends there and I can walk away a happy man.
However, if this is overclocking my CPU and will shorten the lifespan/make it overheat etc. etc. then I'd rather a different way to get the most out of my 2400MHz RAM.
I then found a new processor, a 6th gen Core i5-6600K which (from the website I'm buying from's description) says that the memory controller accepts 2400MHz DDR3 RAM. It's a bit pricier, but performs a bit better anyway and being newer it'll hopefully last longer (citation needed). However, I have been searching for quite a while now and cannot find a single motherboard that both has an LGA 1151 socket for the CPU and accepts 2400MHz DDR3 RAM.
Ultimately, it would be easiest if the 4690k does work with 2400MHz RAM without consequences, but if it doesn't then I desperately need advice.
Thanks in advance!
EDIT: OK I just found out that the 6600k has a memory compatibility of only up to 1600MHz RAM, just like the 4690k. My question still remains though, will changing it to run at 2400MHz be harmful to it, or will it even be necessary?
Thanks in advance!
