Processor running at 800mhz instead of 3ghz
Shock3R
14
I've just recently purchased a new processor and motherboard. The processor is a AMD Phenom II X4 945 Deneb 3.0GHz Everything runs perfectly fine, but for some reason my processor is only running at 800 mhz instead of 3ghz.
Here's the processor: AMD and here's the motherboard: ASRock
Anyone know what's wrong? =(
Shock3R
14
Newegg accidentally shipped you an 800mhz AMD Athlon 1.
Get a RMA
Um my computer reads the name correctly, just the 800 mhz that's wrong. The box it came in was correct and all.
They are messing with you |:p
CoolnQuiet turn down your cpu frequency for maximum power saving.
Shock3R
14
This is my first day on this website, how is it my fifth thread? I'm just looking for a solution to my problem, sorry to bother..
JD45093
24
Here is a test. Try running Prime95 and your processor should clock up to 3.0Ghz if it doesn't then there is a problem. So just check the clock speed wile running this program.
Shock3R
14
It stays at 800 mhz. =/ I'm thinking that I need to do somethings with the jumpers, not sure how that works -- perhaps change the multiplier to 15? It's at 4...
royalcrown
That is your problem exactly, set it to your cpu speed / 200 so 3 ghz/200 = 15 :)
Shock3R
14
I am running the P1.40 Bios. It detects my card but for some odd reason at 800 mhz and not 3 ghz. I've tried changing the multiplier in bios from 200 x 4 to 200 x 15 to get the 3ghz, but my pc doesn't load up if I do. I was reading something about jumpers to change the multiplier? Anyone know? :X
Shock3R
14
What does that do? It's a brand new motherboard and processor :X and if it does do something, how do you do it?
redkachina
105
Strange problem indeed..945 got its multi locked too..you can't change it. And running P95 also didn't throttle the speed up to 3Ghz.. usually its because of C&Q..no idea LoL.. try reflashing the bios to slightly older ones? see if its running @ 3.0Ghz or not..
