G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
I know upfront this is a way old and slow board, but not much I can do about
that.
Anyway I have what's identified by Belarc Advisor as an Hsing 586TX Rev 3.1
motherboard. The AMI BIOS is 0626, 7/15/1995. The processor was upgrade
to a 200Mhz processor, but the bios did not recognize the change nor do I
see a way in the BIOS settings to change the processor speed. After
searching the net a bit, I see on these old motherboards changed processor
speeds were often needed to be set via jumpers on the motherboard. I found
the voltage changes for the processor, but I can't find where to change the
processor speeds. I also don't know what jumper settings are needed to
identify to the motherboard that now a 200Mhz processer is present
(previously it was 166).
Can anyone help? Thanks in advance,
Joe
joemagiera@ameritech.net
that.
Joe
