Please suggest which processor should I choose among i3 8100 / i5 8600k / Ryzen 5 2400 G for general computing tasks with multi tasking and light gaming.
Thank you for your suggestionIf your not getting a dedicated GPU then the 2400G is the best out of the 3 for gaming and with the 4 cores & 8 threads it handles multitasking quite well.
Your welcome, if you do get the 2400G pair it with a B450 motherboard (better memory compatability/stability over B350/X370) and either 3000 or 3200mhz memory in dual channel as it makes a big difference in performance for AMD Ryzen CPU's (nearly a 20 FPS difference over 2133 depending on the game).Thank you for your suggestion
