Processor temps. - Difference in readings
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Has anyone experienced software apps reporting different values for CPU
temps than the BIOS?
My BIOS reports 45-46C
Motherboard Monitor and Aida32 report 91-92C
Has anyone seen this before? I'm baffled. Asus P4T-M Socket 423 850 based.
Pentium 4 1300MHz.
Replace the obvious with "hotmail"
Hi,
It's hard to believe a P4 1.3 G can reach 91 to 92 degree C.
In fact the CPU burned at this temperature.
BTW, even the temp showed by the BIOS is too high at 45-46 degree C unless
it was measured at full loading.
My P4 2G northwood CPU run at 32 degree C at room temperature 23 degree C
and my P4 530 Prescout run at 40 to 60 degree C.
I would suggest you to check the chassis fans and CPU fan to ensure they are
running smoothly. Also make sure there is no blocking of ventilation inside
the chassis.
Peter
> Pentium 4 1300MHz.
> CPU temps than the BIOS?
> based. Pentium 4 1300MHz.
92°C?! I don't *THINK* so! There is no way in the Universe that a P4 1.3GHz
would boot with temps that high - that's 20°C over the Intel specified
maximum! I think it's more likely they're reporting 92°F (around 34°C) - or
you have them set up incorrectly.
Facon - the artificial bacon bits you get in Pizza Hut for sprinkling
on salads.
> Pentium 4 1300MHz.
I'll believe the BIOS temps. The MBM temps are way too high. With MBM, bring
up the Settings panel, select Temps, then select CPU, then walk down the list
of board sensors until you find one that agrees with the BIOS. Aida may have
something like MBM's choices; I stopped using it in favor of Everest, which
had the right temps out of the box.
Cheers, Bob
"Peter" <Peter@discussions.microsoft.com> wrote in message
news:2A8B20CE-5B48-44E1-9CA4-30A9B275AD44@microsoft.com...
> Hi,
That's what I thought as well. Yesterday, we opened the cabinet and the
heat sink fins were quite warm; this is in spite of the time elapsed for
shutting down, opening the cabinet screws (server build here) and detaching
the sink equipment.
The temp has always been around 46C, even when I bought it. Probably
because I stay in the tropical region and the ambient temp is around 30C.
And yes, this is usually full loading.
> are
> inside
> the chassis.
All seems to be OK on that front, as I opened it all up yesterday. Also
scraped off the thermal paste and applied fresh paste. Thanks for your
help.
> Peter
>> based.
>> Pentium 4 1300MHz.
92 C will blister your fingers, 40 C is 104 F and is hot to
the touch but will not blister. Warm to the touch is
anything above skin temperature or about 90 F. Ask a nurse,
37C is normal human internal body temp or 98.6 F
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
"DILIP" <dilipr@#*&!%l.com> wrote in message
news:O7NNEca3EHA.2676@TK2MSFTNGP12.phx.gbl...
| > Hi,
degree C.
cabinet and the
time elapsed for
here) and detaching
| the sink equipment.
it. Probably
is around 30C.
fan to ensure they
| > are
ventilation
| > inside
| > the chassis.
yesterday. Also
Thanks for your
| help.
| > Peter
Socket 423 850
| >> based.
| >> Pentium 4 1300MHz.
Both software report the temp in degrees C. When I change the units, it
reports ~194F. There's another thing I should mention here that really got
me worried - yesterday for the first time I got a BSOD crash while playing
GTA - And this has never occurred in XP here, before. The crash dump was
written and the system forcibly rebooted. All other software and hardware
work perfectly - The system is a fast one, generally.
"Miss Perspicacia Tick" <misstick@lancre.dw> wrote in message
news:74Htd.15223$SN6.11733@fe48.usenetserver.com...
> 1.3GHz would boot with temps that high - that's 20°C over the Intel
> specified maximum! I think it's more likely they're reporting 92°F (around
> 34°C) - or you have them set up incorrectly.
> on salads.
None of them are around 46-50C except the case/board temperature which is a
separate entity and is ~40C, correctly reported in the BIOS as well as
software. As for AIDA32, it has reported correct temps in the past, but I
loaded Everest anyway, and the result is the same. The puzzling thing is
that all these readings would correspond typically to one and the same
sensor; wouldn't they? This difference is extremely odd. One of my geek
friends suggested re-flashing it and changing the battery. I re-flashed,
but the result is the same. The only thing left to do would be to change
the battery - But FWIW the computer keeps good time and shows no signs of
failure on that part.
I'll can attach a screenshot of the MBM readings if it helps.
"Bob Willard" <BobwBSGS@TrashThis.comcast.net> wrote in message
news:%23225$LZ3EHA.3336@TK2MSFTNGP11.phx.gbl...
>> based.
>> Pentium 4 1300MHz.
> bring
> list
> have
> which
> Cheers, Bob
That's CPU temperature, Jim. We are talking about touching the fins of a
heat sink (these are already at a lower temp than the CPU). The are thin
strips of metal, have a high heat transfer co-efficient and an enhanced
surface area for heat dissipation and typically would lose large amounts of
heat very fast through conduction and radiation, apart from natural
convection. Temps can fall *quite* fast.
"Jim Macklin" <p51mustang[threeX12]@xxxhotmail.calm> wrote in message
news:OeC6ySb3EHA.208@TK2MSFTNGP12.phx.gbl...
> | > Hi,
> degree C.
> cabinet and the
> time elapsed for
> here) and detaching
> | the sink equipment.
> it. Probably
> is around 30C.
> fan to ensure they
> | > are
> ventilation
> | > inside
> | > the chassis.
> yesterday. Also
> Thanks for your
> | help.
> | > Peter
> Socket 423 850
> | >> based.
> | >> Pentium 4 1300MHz.
CPU or heat sink, the temperature effect will be the same.
The comment was made "the heat sink fins were quite warm"
and I simply supplied a reference to that subjective
feeling. But if the CPU was at 92C the heat sink would have
been conducting that temperature to the fins.
BTW, temperature and heat are two different things.
If you have a gram of nitrogen gas at a temperature of 100 C
and you place your hand in the gas, it will not cause any
injury since there is only one gram of a low specific heat
material. But 1 gram of iron at 100 C dropped in your hand
will burn your skin.
BTW2, I know what a heat sink is.
news:uRZf9yc3EHA.3820@TK2MSFTNGP11.phx.gbl...
CPU). The are thin
and an enhanced
large amounts of
from natural
in message
to
nurse,
message
| > | > Hi,
| > degree C.
the
| > cabinet and the
the
| > time elapsed for
build
| > here) and detaching
| > | the sink equipment.
bought
| > it. Probably
temp
| > is around 30C.
CPU
| > fan to ensure they
| > | > are
blocking of
| > ventilation
| > | > inside
| > | > the chassis.
up
| > yesterday. Also
| > Thanks for your
| > | help.
| > | > Peter
P4T-M
| > Socket 423 850
| > | >> based.
| > | >> Pentium 4 1300MHz.
