Hi everyone thank you for reading and helping! So I bought a prodigy M for a A10 7850k build and basically wondering what the best fan set up is to keep temps low as possible...here is where I am at now.
Top: 2x120mm Exhaust (Should these be intake?)
Front: PSU goes in vertical so no fan can go here PSU fan is intake blowing air to bottom/outside area
Rear:140mm Exhaust (maybe intake with 2x120mm exhaust?)
Bottom:230mm Intake
Probably will be throwing a r7 250 in there as well which would be on the upper half of the mobo this case for some reason make mobo upside down.
Phanteks PH-TC12DX CPU Cooler will be on the apu as well plan to OC
Thank you everyone for reading and providing input I really appreciate it!
Bottom:230mm Intake
