Hello all,I recently reinstalled windows 7 but it won't accept my Product key which is on my laptop back. What should I do? I thought that one will work.
Are you trying to reinstall the OS on that particular laptop? If so, you need to use a version similar to that one (OEM, 32 or 64 bit, etc).
If you are trying to install it on a different machine it won't work, since it's a OEM key. You need to get a new key from MS.
Are you sure it is the exact same version of Windows 7(how did you get a copy of Windows 7, was it one of the digital river iso's[those are the only ones to trust]). They also have 64 and 32 bit versions(this is important as the product key will not be the same for both.).
You may be able to contact MS with the activate by phone method to see if they can get you setup.
Yes I'm installing on same laptop. It was Win7 home premium 64bit and I installed windows 7 home premium 64bit. So its same isint it? I installed from original windows 7 cd
That product key is the manufacturer's OEM product key. Did you use the re-installation disk to re-install the system? If it is the same laptop/computer you can call Microsoft and obtain an authorization as long as nothing else has been changed. OEM Licences are not transferable from computer to computer.
There are several versions of Windows 7, the label should say which one it's for. You have to reinstall the exact same version. I've found that OEM versions don't like to verify over the internet and you may have to call it in.
From the computer manufacturer; for a small price to cover CD plus shipping. Any re-installation CD from the same manufacturer, same OS, will work as long as you have the product key.
You don't need the OEM disk. I've installed from standard install disks onto laptops several times. Perhaps you can provide the error message you're seeing, it's entirely possible that if the label is hard to read that you have the right version but are entering a bad key.
OMG bro thanks,its activated! jesus,it was T instead of Y lol.
Just as a precaution, type out the activation code and save it in a separate file. I have an Excel spreadsheet for each one of my computers (and friends' computers that I work on) that includes all the computers specs as well as the Windows activation keys. (CPU, RAM, Motherboard, BIOS, Graphics, OS with codes, MAC Addresses, HDD).
