Programing Notepad Help
dvilay
How do I start a program. I tried in the notepad.
@echo off
Start ooVoo.exe
Start ooVoo.Ink
Start "C:\Program Files (x86)\ooVoo\ooVoo.exe"
Start "C:\Program Files (x86)\ooVoo\"
None work.
Help Pleas, what are you supposed to put after the start t launch ooVoo.
If the program is a 32-bit program you should point to C:\Program Files (x86) and if it is a 64-bit program you should point to C:\Program Files. There are a couple of ways to find out where the program is located. Do a search using Windows explorer, right click on the shortcut and click on properties, and you can look in the Program Files (x86) and Program Files folders.
To break it down a little:
cd C:\Program Files (x86)\ooVoo is the command to change directory followed by the path to the ooVoo folder in Program Files (x86)
As you already know ooVoo.exe is the executable file.
Syntax for the Start command: http://www.computerhope.com/starthlp.htm
For info on DOS commands:
http://www.computerhope.com/msdos.htm...
It worked but how do I find out other programs. What do I put for other programs, where did you find that
http://pcsupport.about.com/od/commandlinereference/tp/dos-commands.htm
Help with DOS batch files:
http://www.wikihow.com/Write-Batch-Files
http://www.computerhope.com/batch.htm
