Programs missing from Control Panel (can't uninstall programs)
Triple0
13
So I updated to Win 10. Installation went without problems. The only problem I have is that control panel seems to not read all my files so I can't uninstall/modify any of my existing programs.
To be more specific
Win8 : Like 100 programs in CP
Win10 : Like 10 programs (all installed after the update)
Current Control Panel
How can I make control panel check my PC to find all my existing stuff?
Thank you for the help
You could try the Revo Uninstaller. That's always worked for me. I'd also run "sfc /scannow" from an administrator command prompt.
Good luck.
