Hi,
I just get Project Cars 2 and I have FPS drop after I tried various settings.
My PC:
GTX 1070 G1 OC 8GB
i7 6700
16GB DDR4
1440p WQHD Monitor
I set the resolution to 2560x1440 x 59hz and if I turn V-Sync on or off I set the quality low or ultra, MSAA off or high I always get FPS drops.
Most time from 60 to 57 fps. It is very annoying.
I tried to monitor the PC how to work under the game.
GPU's power was 70%, on 1995mhz, and 3GB Vram was used from 8.
I don't know what should be the problem, but I don't enjoy playing because in every 3 seconds there is a big lag.
Thank you!
My PC:
GTX 1070 G1 OC 8GB
i7 6700
16GB DDR4
1440p WQHD Monitor
Thank you!
