Project ENB (Skyrim) for my System?
denus3
160
Hello guys, I want to enhance my skyrim by using ENB and many more mods.
I want to play skyrim at 60 FPS with (Project ENB, CoT, Flora Overhaul, Trees HD,Texures, Fire Effects HD, Pure Water, SMIM and other texture replacing mods for drgons, weapons, blood, sky, etc...) and i play 1080P
I have pretty powerfull system: i7-3770K(4.4GHz), 8GB 1866MHz CL8, 128GB SSD, 1050W Corsair and a MSI GTX 780 Lightning.
I will OC my GPU to 1120MHz and GPU Boost 2.0 will push my card to 1200+Mhz easily cause i have good ambient temp and case cooling so I will have nice GPU power.
So will my system run Project ENB and all those mods at 50-60 FPS?
Is it best MOD configuration for skyrim?
Anybody know better ENB that i could run at 60FPS with that mods ?
Your system is solid and should run those mods with no issues at the FPS you desire.
Be prepared for some trial and error though. Not all mods like each other and some will have conflicts which may cause CTD's or slow down the performance. Especially the HD textures and by my experience the armor and weapons mods can cause crashes.
I used to use the Realistic Lighting ENB on my game and it looks pretty good, you may want to give that one a try, but know that it makes the dungeons and other indoor areas much darker.
I also recommend you try Sky UI, its a good mod, and the one that adds the roads to the map, that is a quality of life changer.
