Greetings!
I have a fairly highpowered computer (2.4ghz/3gbRAM/1.5tbSTG/512mbVideo, MSVista) which I use as both a family PC and home theatre component. It has SVGA, DVI, HDMI, Component & Composite outs. (single video card & TV tuner). I would like to be able to have it put out video to my DVI monitor and my 1080p projector at the same time (or rather, one or the other without having to rewire every time I want to switch which one I want to view on).
My problem is that if I have the monitor connected DVI (only option) and my projector connected HDMI, only one will get a signal. Is this as simple as "you can't do that with one video adapter"? Although it has multiple outputs, I believe it is only single monitor capability. Would an HDMI splitter of some kind work? Adding to my struggles, both the monitor (DVI) and the projector (HDMI) are running over 25 foot cables (rated for the long distance), and any kind of signal interruption (turning the monitor off and back on again, switch user) results 99% of the time in the monitor signal not coming back (the only thing that works is a restart or a standby/wakeup.
The performance of the video is great, and it looks just fine on the big screen, watching DVDs, browsing the net, internet video (hulu/whathaveyou), programs recorded with mediacenter and home videos. But I would love to use my computer on my big fat eight foot wide motorized ceiling recessed turbo charged screen!
Thanks for any help!
Regards,
Kevin
Regards,
Kevin
