Hi all!
I've had my current system since 2012 and it does what I need. The most resource intensive games I play are Star Wars Fallen Order and Mass Effect Andromeda. So a budget/mid upgrade is fine, I don't need top of the line.
Unfortunately my system is not compatible with Windows 11 so I need to upgrade.
My proposed upgrade is
1. Motherboard: MSI MAG B850 Tomahawk MAX WiFi
2. CPU: MD Ryzen™ 5 9600X
3. RAM: 32GB (2x16GB) G.SKILL Trident Z5 Neo RGB DDR5 6000MHz
4. GPU: MSI GeForce RTX 5060 8G Shadow
Is this a good proposed system? Anything I've missed or should look at instead?
Also I have some old components I proppse to re-use including my SSD and HDDs, but had two big questions:
1. Would my ToughPower 650W PSU be enough to run the above?
2. Would my old Asus GeForce GTX 1050 Expedition OC 2GB GPU work with the above CPU, RAM, and motherboard?
Thanks very much in advance!!!
