C cbalajidba Nov 4, 2018 1 0 10 Nov 4, 2018 #1 Hi, Can you tell me what are the pros and cons of enabling bluetooth? Regards, Balaji.C
USAFRet Titan Moderator Mar 16, 2013 179,837 22,145 184,590 Nov 4, 2018 #2 cbalajidba : Hi, Can you tell me what are the pros and cons of enabling bluetooth? Regards, Balaji.C If you have a device that requires bluetooth connectivity, it needs to be ON. Otherwise, leave it OFF. Upvote 0 Downvote
A_Goat Distinguished Nov 30, 2014 1,550 32 20,790 Nov 9, 2018 #3 Um, Well the only pro would be being able to connect to your bluetooth device. a few cons would be; countless security vulnerabilities Increased EMI which can decrease your cell signal strength decreased battery life possible health concerns Upvote 0 Downvote
M mermarinc Nov 9, 2018 1 0 10 Nov 9, 2018 #4 Pros of enabling Bluetooth is that it is cheap and easy to install. Cons can be poor security and slow data transfer. Upvote 0 Downvote
S spikeysonic Prominent Jul 23, 2018 189 0 580 Nov 24, 2018 #5 Im with USA turn on in use turn off when not in use, pretty simple Upvote 0 Downvote
