Proxy setting???? Please Help
  • Thread starter Thread starter Al
  • Start date Start date
Al
558
Archived from groups: microsoft.public.win2000.group_policy (More info?)
Hello,
I am trying to figure out how to set proxy setting for group policy in windows 2000 server. I need
to know where to go in GP to set proxy setting and to set up bypass proxy settings.
Please Help me.
Thank you very much for you help.
Al
my windows is dutch so there could be a small difference in the translation
user settings > windows settings > internet explorer stuff > connection >
proxy settings.
succes
Omko
"AL" <anonymous@discussions.microsoft.com> schreef in bericht
news:060CE8DA-A47F-4A31-BDCA-455CEC0B35AD@microsoft.com...
> Hello,
settings.
> Please Help me.
> Al
Hi omko,
That's ok so far.
But when I change the proxy settings, the address will not be fixed after I
log off an back on again.
Is there a chance to set the proxy settings - and the startup page as well -
to a default, everytime a user logs on?
Dirk
"omko h" <omkoh@hotmail.com> schrieb im Newsbeitrag
news:uesNTQANEHA.268@TK2MSFTNGP11.phx.gbl...
translation
> proxy settings.
> succes
> Omko
> > Hello,
proxy
> settings.
> > Please Help me.
> > Al
I think you are doing something wrong......
make sure you set the proxy settings in the GPO this is applied last.
you can use gpresult to see which policys are applied
http://www.microsoft.com/windows2000/techinfo/reskit/tools/existing/gpresult-o.asp
greets Omko
"Dirk" <dirk.gringel@info-systeme.com.nospam> schreef in bericht
news:%23jez08HNEHA.556@tk2msftngp13.phx.gbl...
> Hi omko,
> That's ok so far.
I
well -
> Dirk
> translation
> > proxy settings.
> > succes
> > Omko
> > > Hello,
> proxy
> > settings.
> > > Please Help me.
> > > Al
"omko h" <omkoh@hotmail.com> wrote in message news:<#hc8ZCyNEHA.4036@TK2MSFTNGP12.phx.gbl>...
> greets Omko
> > Hi omko,
> > That's ok so far.
> I
> well -
> > Dirk
> translation
> > > proxy settings.
> > > succes
> > > Omko
> > > > Hello,
> proxy
> settings.
> > > > Please Help me.
> > > > Al
Al,
if you are making modifications to a workstation that is assigned to a
managed environment, your local changes to the proxy list will be
overridden periodically by the ie maintenance settings gpo. you have
to make your changes to the gpo. open gpedit.msc editor and make your
changes in the following area.
the settings can be made in 2 places within your ie maintenance
settings gpo. look under User Configuration, Windows Settings,
Internet Explorer Maintenance, Connection. On the right of the screen,
make your changes under the connection settings option ONLY! on the
popup screen, select import the current connection settings. this will
take you into the familiar internet options connection popup. make
your exceptions under the LAN settings button. if you make the
changes to the proxy exceptions list using the Proxy settings option,
you will be limited to 256 characters in the exception list window.
this can cause problems for you later if you have multiple entries.
i hope this helps you.
- Thom
