PS2 front USB ports and Hard Disk
G
Guest
Guest
Archived from groups: alt.games.video.sony-playstation2 (More info?)
Hello all,
Just bought an old PS2 Ver 5.
Can somebody tell me what the connections are for under the controller
input? Also which type of 200 gb hard drive will fit into the bay so i can
transfer my games onto HD?
Thanks
Jazzer
you can use a USB hd, not too fast tho.
you can use a maxtor 200gig with hdloader
hdloader.net
On Mon, 25 Apr 2005 06:58:26 +0000 (UTC), "jazza"
>Thanks
>Jazzer
"jazza" <lenrobertsuk@hotmail.com> wrote in message
news:d4i4ei$2cu$1@nwrdmz02.dmz.ncs.ea.ibs-infra.bt.com...
> Hello all,
> Thanks
> Jazzer
Their is also a firewire connection to link two PS2's together, as for the
HD, good luck, a friend of mine who does those converts tried just using
the one I got for FP XI to run my games off of even after moding it but no
go.
> Hello all,
The USB ports can be used for certain add ons like keyboard, eyetoy, that
sort of thing.
