PS2 Slim Ribbon Cable
Iridescent_Blue
26
Does anyone know where i can find a PS2 Slimline power button ribbon cable, 8 pin, 5mm W x 4cm L? I'm repairing a PS2 that works apart from this cable being an issue and need a ribbon cable for it, the only one I've found so far is from Ebay but I'm waiting on a reply from the seller before i buy it but i need one ASAP. Cheers, everyone!
D
it will cost u less to buy a ps2 than all the things u need to fix it u can find the cheapest for 5euro up to 30euro if its any more from that dont buy it
Ah okay, I'll have a look around, then! Cheers! ^-^
