PS3 HDMI back to normal cable problems.
sav5070
Hello, A couple days ago I connected my PS3 up to an HDTV using a HDMI cable. today I went to connect it back to a normal normal TV using the red, yellow, and white cables. the problem is my tv will not display anything. I believe its because the PS3 is still set on HDMI but i dont know how to change that if I cant see anything.. can anyone help?
Porter707
16
I know this happened when I connected my PS3 to a HDTV as well. I had to reconnect the PS3 to the HDTV and reset the output to a VGA connection before it would properly display on a Regular TV.
So just reconnect the PS3 to the HDTV via the HDMI cable and change the settings to VGA then reconnect to the Regular TV via the VGA cables.
G
Guest
Guest
Yep pretty much what sav said. I've done this many times myself, it even tells you how to fix it in your ps3 manual intructions that came with it.
