Ps3 HDMI to DVI PC Monitor HELP!
jaggsta
42
I bought a HDMI to DVI adapter and used my HDMI Cord from my TV plugged it in to PC Monitor with adapter nothing will work 480p-720p-1080i-1080p no picture will show up i tried every setting 1 by one.
My Monitor is HP S2031 HDCP compatible.
Im thinking the Adapter is Broken.
The Stealthinator
1,710
You say that you plugged the cable into your monitor, but you never said you plugged it into your PS3 on the other end. Not that I think that's the problem, anyway. I once had a set-top box which would connect via HDMI to my TV, but if I used an HDMI DVI cable (HDMI out from the set-top and DVI in to the TV), no picture would show up. I never figured out why, but maybe some devices just don't work with some cables.
