I use my PS3 to stream media from my computer via PS3 Media Server.
Works well, used it for years. All of a sudden, today I can't connect.
Turns out PS3 won't connect to internet at all.
I didn't change anything, there's no power outage, nothing at all.
Just stopped working all of a sudden.
Spent hours trying to fix it, and now entering it manually even.
The attempt to obtain an IP address has timed out
Even when I enter everything manually, the IP is a success, but the internet fails.
I have reset my PS3 to default settings.
Reset my router to default settings.
Didn't fix a thing.
The first error code was 80130182
Then, after resetting, it's 80710102
Here is what I have entered into my PS3 (With the IP ending in 127) created unique IP
What it looked like, but with the primary DNS same as above pic ^^^
And the error
This is now beyond my comprehension.
PS: I'm hardwired via coax, split between my streaming computer, via router
In other words, I'm technically connected to my computer almost directly
If I can't use the internet due to the IP, can I piggyback off of my computers internet?
Didn't fix a thing.
And the error
