PS3 on Monitor vs TV. Help please.
aspec
86
Would using HDMI-to-DVI to connect my PS3 to my pc monitor look better than it would on my TV? the TV is just a regular 27" with no hdmi or anything and when pc was hooked to it max resolution was 1024x768 it said on ATI's CCC and the PC monitor is 1600x900 + it would be digital over the normal analog(red/white/yellow plugs) the TV uses. would the difference be really noticeable?
PC Monitor specs:
http://www.samsung.com/hk_en/consumer/computer-peripherals/monitors/giant-series/LS20CMZKFV/XK/index.idx?pagetype=prd_detail&tab=spec
TV specs:
http://www.tacp.toshiba.com/televisions/product.asp?model=27A45
HDMI-to-DVI cable(not sure if theres a better one but think this is right?):
http://www.amazon.com/DVI-D-Cable-Meters-Plasma-Computer/dp/B000PJUJ98/ref=sr_1_3?ie=UTF8&s=musical-instruments&qid=1262866311&sr=8-3
also if i hooked my pc to the vga port on monitor while ps3 is hooked to the dvi port is it possible to change to which you view? incase i need to use pc? or will i have to unhook ps3 and rehook pc back up?
It would almost definitely look better on your monitor. I'm not totally sure, but there *may* be a bit of scaling as your monitor isn't native 720p or 1080p, but right in the middle, but as it's still 16:9, I don't think it'd be an issue. Depending on your monitor, there should be a button to switch inputs so you can go back and forth between the DVI and VGA, but I didn't see anything like that on the page you posted (doesn't necessarily mean it's not a feature, but just an obscure one they wouldn't think to put on the spec page). Just know that if you hook your PS3 to the monitor with an HDMI-to-DVI cable, you'll have to output your audio separately, as DVI doesn't carry audio. You'll leave your old output cable in and hook the white/red cables up to a speaker system or something, or use the optical audio out if you have a system that has that feature.
