[SOLVED] PS4 Bitstream or Linear PCM?
animematic
114
4
18,685
Hi so first sorry if this is the wrong area wasn't quite sure if this was the right one but since it was audio related thought it might be here.
So just curious but what Setup is best for my PS4 Pro? I use a standard HDMI output from the system directly to the TV and just use the TV's built in speakers.
The default setting is Linear PCM and the options menu that appears while a blu ray is playing also has it set to Linear PCM.
I'm just wondering because I've been watching some anime Blu Rays that seem to have some audio sync issues with the English dub track. I figure its probably mainly due to the Blu Rays themselves but noticed when I switch the options menu setting from Linear PCM to Bitstream it seems to fix the issue.
Should I keep the changed settings or go back to the default Linear PCM?
