PS4 HDMI to DVI Cable No Signal
Kybz
106
So I bought a HDMI to DVI-D cable which I plugged into my PS4 and Viseo 243D monitor. When I turn it on, theres a message on my monitor saying "check cable". I tried booting PS4 in safe mode but it doesn't work. Sometimes the message goes away but instead the screen is lighter than normal - a blue/grey colour which tells me that there is a signal there.
Any ideas on how to make it show up?
I know PS4 doesn't support DVI signals but I've seen people do it.
Ok guys, pretty embarassing fix. Basically plug in the DVI cable AS HARD AS YOU CAN into the monitor. I used the same force I usually use to put in a standard DVI cable. I ended up getting proper angry and just shoved it in has hard as I could and it started working LOL. It seems that this cable requires more of a force to go in properly? I don't know but it worked for me.
If this doesn't work, turn off HDCP from PS4 Menu.
If you don't know how to do this: https://www.youtube.com/watch?v=I14OuVNtQpo
