PS4 Pro Miles Morales issue
JakubFindra
149
Hello, I've got myself a PS4 Pro two days ago, and upgraded the HDD to an SSD the same day. I installed my 2 digital games, and a physical copy of Marvels Avengers, but (physical) Miles Morales gets almost halfway (~19gb/42gb), and then just spits out "an error has ocurred", and then closes the installation screen, and in the main menu there is Miles with a little X on the bottom. When I open it, it says "unable to open application (error CE-30005-8)"
I've tried:
Rebuilding database
Cleaning the disc
Letting the pro rest without power
install without internet
None of these have worked, but I want to play the game. Please help
(I haven't found a better place to post this, so I'm hoping here is OK)
This version?
https://www.amazon.com/Marvels-Spider-Man-Miles-Morales-playstation-4/dp/B08KSN7GF4?th=1
However: if you google "Miles Morales install failed red x" and start looking through the resulting links you may find a fix that will work. Include the error code in the search criteria as well.
For example:
https://www.reddit.com/r/PS4/commen..._this_cross_mean_ive_just_finished/?rdt=40011
https://gamefaqs.gamespot.com/boards/300970-marvels-spider-man-miles-morales/79204218
Second link matches the error code.
"Cannot start the application. (CE-30005-8)"​
Try PS4 fixes first, then try PS5
Not sure what else to suggest.
