PS4 VGA to HDMI connection not working
PyroMania935
So I have a Philips 193v5lsb2/62 18.5" monitor that I'm trying to connect my PS4 to. I bought a VGA to HDMI converter and connected everything. However, the message 'Attention, check cable connection' kept popping up. I've tried turning off HDCP, lowering the resolution to 480p and going into safe mode but unfortunately nothing has worked. Anything you guys think I could do to fix this?
I've previously used the PS4, and I manually turned off HDCP (Settings> Systems > Unticked the box) but it still doesn't work.
