I've recently been getting a more and more serious problem of being barely able or even unable to power on my computer using normal, conventional methods. After my most recent (and most serious) case of this, which I worked around by unplugging the 24-pin and shorting it into the on state with a paperclip and hot plugging it after a small sit time, I went into my hardware monitor and noted that the -12V rail is running at -6V. I am not sure what to make of this anomaly, seeing as my computer is able to run with it like that. If my hardware list is any help, I'll list it.
1x 1TB 7200RPM HDD
1x 320GB 5400RPM HDD
EVGA GTX 750 FTW 1GB GPU
ASUS M3N78-EM Motherboard
2x Crucial Ballistix 2GB 800MHz DDR2 Ram
2x Corsair 2GB 666MHz Generic DDR2 Ram
AMD Athlon 64 X2 4050e OC'ed from 2.1 GHz to 2.63 GHz, OV'ed 50mV
Via ENVY24 PCI audio card
Generic DVD drive
And for the power supply
I ripped this thing out of a Dell XPS 410 with a dead motherboard.
it's rated 375 watts
and it's sized as well as wired very wierd so I have to turn it backwards to get all the wires connected right and to mount my case upright without it falling, I have to wedge a stick between the PSU and the bottom of the case. It works, what can I say?
1x 1TB 7200RPM HDD
Generic DVD drive
