So I know most PSUs with a 20 pin only cable are pretty much junk nowadays for powering any system with a 24 pin.
However this happens to be an FSP 350W Unit, which is decent enough for a basic PC.
I've read plugging a 20 pin into a 24 pin socket can work, however can lead to some issues.
Therefore I was thinking of buying this: 20 Pin to 24 Pin Adapter
Will this give more stability than just using the 20 pin in the 24 pin socket? and most importantly, will it work to power the PC constantly with no random shut down?
Thanks.
Thanks.
