PSU 24 pin cable missing pins?
Justin21
Commendable
Jul 14, 2016
101
I completed my first build yesterday, and of course with my luck, it did not work. I have tried various things and then I took the power supply out to test it. It works, but when I was plugging in the 24 pin cable, I realized 2 of the metal pins inside are gone on one end, and the other end of the cord has 1 missing as well.
The end that goes into the PSU is missing 2. If it is plugged in, it would be the 4th column from the right, top and bottom is missing.
The end that goes into the motherboard, has the bottom one from the 5th column from the right missing.
Is this normal? Could it have something to do with my PC not turning everything on? (It would make a vrrring sound for a second and then stop, power led stayed on)
I appreciate any help, thank you
Yeah I hooked that up. Now I have tested the power supply, I am trying to clear CMOS, I took everything apart to "breadboard" the mobo.
Gigabyte H170 Gaming 3 Motherboard.
And yeah, it was an 8 pin.
