[SOLVED] PSU 4 pin peripheral with PC 2 pin (peripheral or molex ?)
telgou
27
all molex drives would need a full pin connector and not only yellow or red cables to function. Like HDD or DVD. These connectors would fit but not work.
Connect the yellow one to a 12Volt fan or fan speed adjuster and the red one to a 5Volt fan device.
Which power supply are you using?
A full Molex connector would connect to DVD, HDD devices only.
Also have a look at
https://en.wikipedia.org/wiki/Molex_connector
the two pin molex usually connect to fans or similar, which device do you wanna connect to the PSU?
I honestly don't know lol there are a bunch of cables coming from the top front of the case, it's hard to isolate which ones belong to which device/port. (but i will try to check harder, i have a DVD drive so one of those must be his)
My problem is that the taller PSU one doesn't seem to fit with neither of the PC's (the short does)
Also have a look at
