PSU 8 pin connector to 4 pin connector
wfreeman
5
I had to replace my MOBO recently with a Gigabyte GA-Z68A-D3H-B3
The 8 pin cable from my PSU with the label CPU on it, does not split into 2 pieces. My MOBO only has a 4 pin 12V for the CPU.
Is there some sort of converter I could buy, if so, how safe is it? And which ones would you all recommend?
The PSU is a Seasonic 80 Plus Platinum 860W SS-860XP
Thanks in advance!
