Question PSU advice for my build please
Jul 28, 2020
13
I put together a build with a ASRock B550 Taichi mobo and a Sapphire Nitro+ SE GPU card. Pcpartpicker computed the power load for the whole build around 450W. I had originally ordered a Seasonic Focus PX 750W PSU from Newegg, but it's backordered and I don't know when it will ship so I'm thinking about getting a different PSU since all the other components are arriving in the next day or so. Newegg had it listed for $144 which seemed like a great price. PSUs seem to be in short supply these days, so there aren't a lot of choices. Another concern is that the mobo needs two 8 pin power connectors along with the 24 pin, and the graphics card needs two 8 pin. I'd like solid high quality PSU, but it doesn't have to be Platinum. Gold is probably okay. I'm thinking about the be Quiet! Dark Power 11 750W which seems to be a good PSU for $179 on amazon. Thoughts?
Thanks in advance.
Barty1884
5700XT?
You'd be fine with a quality 650W unit too...
Right now, the best 'value' would be in the CX650 or CX750 ($80 and $100 respectively on Amazon), and should be available to ship now or later in the week:
https://www.amazon.com/Corsair-Bronze-Certified-Non-Modular-CP-9020122-NA/dp/B01MRW2K7E/ref=sr_1_1?dchild=1&keywords=Corsair+CX+Series+650+Watt+80+Plus+Bronze+Certified+Non-Modular+Power+Supply+(CP-9020122-NA)&linkCode=gs3&qid=1596560543&sr=8-1&tag=pcp0f-20&th=1
After that, the Seasonc Focus Gold 750W is $125 and available as far as I can tell?
https://www.amazon.com/dp/B0778XF1HL?psc=1&th=1&linkCode=gs2&tag=pcp0f-20
The Bitfenix Whisper M 850W is $130 at B&H as a special order. Says 7-14 days, but that's likely their 'normal' standard (although some of their PSUs say 5-7 WEEKS!)
https://www.bhphotovideo.com/c/product/1328661-REG/bitfenix_bp_wg850umag_7fm_whisper_850m_80_plus.html
Jul 28, 2020
13
5700XT?
Thank you for the reply.
Yes, it's a 5700xt GPU.
The Seasonic you listed isn't a modular PSU, and I prefer to have that. I have not heard of Bitfenix so I'll research that. I think I'll give Newegg a couple more days on the Seasonic PX 750W, and if they don't have it by then, I think I'll go with the be Quiet! if it's a quality PSU.
Jul 28, 2020
13
The NewEgg listing has updated today, only looking at a week or two out.
The BestBuy 750W though, despite PCPP listing as in stock, is not when you flow throw to BB
Thanks to all who replied.
I decided on the Seasonic Focus PX 750W PSU. For a short time yesterday, it popped up on amazon for $137. I think that's a pretty good price for a quality Platinum PSU. It'll ship Friday, so I'm set.
