Psu and case fan installation question
wyen78
First time building my own computer so please excuse the newb question.
I have a rosewill hive modular power supply with a diablotek case.
Case: http://www.diablotek.com/index.php?page=shop.product_details&flypage=tpflypage.tpl&product_id=97&category_id=60&option=com_virtuemart&Itemid=53
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817182131
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128495
The case has 4X 120mm fans. Each fan has a male and female 4 pin molex, none have the little 4 pin that would connect to motherboard sys fan header. The motherboard only has 2 4pin fan headers, the cpu fan and sys fan.
The wire bundle from the power supply has 2 male molex 4 pin and 1 small 4 pin which would fit the mobo header.
Do I daisy chain the fans and then connect the small 4 pin from the wire bundle to the sys fan? Or ignore the small 4 pin from the wire bundle? Should I connect each fan directly to the psu (each fan getting it's own molex connector off the power supply)?
Thanks in advance for any help.
