PSU and Case for my build
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Hey guys, i'm looking for a proper PSU and case for my current, recently bought PC.
So, here are the specs:
Intel Core i7-4790k 4.0GHz
LGA1150 Z97 ASUS Z97-A
2x 4GB 1333MHz Silicon Power
Samsung 850 EVO 250GB
Seagate Barracuda 1TB 3.5" 7200RPM
Gigabyte GeForce GTX 970 4GB
Note: I'll overclock both my CPU and GPU later
Now, my options are limited -
PSU; i have to choose from on of - http://www.gigatronshop.com/napajanja or http://www.winwin.rs/racunari-i-komponente/racunarske-komponente/napajanja.html?snaga_filter=55423 (most i can spare for PSU is around 120€ (around 14000 of my currency)
Case; Cooler Master HAF 912 plus, Thermaltake Urban S21 Window, Thermaltake Level 10 GTS Snow Edition, NZXT Source 530, LC Power Pro 971B Infiltrator, Cooler Master 690 III or Corsair Carbide 200R.
If you have anything else to suggest, for example additinal cooler or RAM, feel free to do it, i'll be glad to consider it once i have some more money to spare.
Not all are, some are made by Delta (who are also an excellent OEM).
I think the TruePower Classic is based on the Seasonic-G platform and built by Seasonic for Antec. There won't be a huge number of cables on a 550 or 650W PSU. I think modular only becomes essential when you're going over 700W. If you go for something like a 200R or HAF 912 there should be plenty of space for cable management.
what's your budget on this? I'm going to guess it's at $200 for both PSU and case so here's my suggestion:
Case: Fractal Design Define R5 w/Window (Black) ATX Mid Tower Case ($105.99 @ NCIX US)
Power Supply: XFX XTR 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($61.98 @ Newegg)
Total: $167.97
Generated by PCPartPicker 2015-05-01 07:44 EDT-0400
$167 for a nice case and PSU
Whole Build suggestion?
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($326.99 @ SuperBiiz)
CPU Cooler: CRYORIG C1 65.0 CFM CPU Cooler ($64.99 @ Newegg)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard ($120.95 @ OutletPC)
Memory: Kingston Fury Black Series 4GB (1 x 4GB) DDR3-1866 Memory ($32.99 @ Amazon)
Memory: Kingston Fury White Series 4GB (1 x 4GB) DDR3-1866 Memory ($33.99 @ Amazon)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($119.99 @ SuperBiiz)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive ($69.25 @ Newegg)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card ($329.99 @ NCIX US)
Case: NZXT H440 (White/Black) ATX Mid Tower Case ($108.99 @ SuperBiiz)
Total: $1270.11
Generated by PCPartPicker 2015-05-01 07:49 EDT-0400
Additional notes: On the whole build I just suggested some parts are a little pricier than yours however it's a black and white rig with a very good cooler, everything is overclockable!
don't buy those psu. get a seasonic m12II 620 watts or s12II 620 watts. (these babies are more than enough for your system)
about the case - get whichever you think looks cool. (nzxt s340 would be my choice if ever)
@-HH-: I'm not sure if i was clear enough about this, i MUST choose from the ones i linked, i have no other option... Furthermore, my PC is already bought, so i can't change anything else but things i can add such as RAM or cooler, but they are not my priority now.
@Sig: that PSU was my choice as well, but they don't have it anymore. My primary concern about case is size, so i can be sure everything will fit in it.
Thank you for your answers so far.
This is probably your best bet from those stores and within your budget. http://www.gigatronshop.com/napajanja/antec_napajanje_550w_tp-550c_truepower-51917
It will be fine for overclocking a single GTX 970 and i7. If you want a bit more headroom there's also this in your budget http://www.gigatronshop.com/napajanja/antec_napajanje_650w_tp-650c_truepower-51907
The Antec Truepower Classic is an excellent PSU built by Seasonic. The main drawback is that it's not modular but that feature is outside your budget.
I didn't know Antec was built by Seasonic, thanks for info. I will definitely put this on top of my list now! Too bad this place doesn't offer modular Antec, because, if they did, i would spare some more money and wouldn't even give it a second thought before buying it..
Ok, thank you a lot. I guess that answers the question about my case also!
