Psu and cooling/fan help
4ever1Love
I'm building my first pc, mostly for gaming and I'm trying to figure out what kind of psu I need, a couple wattage calculators gave me vastly different suggested watts. Also wondering if I should get any extra cooling systems/fans. I care nothing for aesthetics, strictly performance.
Build so far
asus sabertooth 990 r.2
amd fx-8350 black edition 8 core 4.0GHz
G.skill rampage x series 8gb (2×4gb) ddr3 1866
Gigabyte radeon r9 280x
Samsung 850 Evo 120gb ssd
Thanks in advance for any help you can give!
Your GPU determines your PSU
http://www.guru3d.com/articles_pages/asus_radeon_r9_280x_top_review,8.html
This is Guru3D's generic power supply recommendation for the R7 and R9 series:
AMD R9 280X - On your average system the card requires you to have a 550 Watt power supply unit.
AMD R9 280X Crossfire - On your average system the cards require you to have a 750 Watt power supply unit as minimum.
If you are going to overclock GPU or processor, then we do recommend you purchase something with some more stamina.
Given your Crossfire MoBo, selection, I'd get a 750 watter if using at stock, and 850 watter if overclocking
http://pcpartpicker.com/part/evga-power-supply-110b20750vr...
http://pcpartpicker.com/part/evga-power-supply-110b20850v1
I think you will find that you cn get 2133 CAS 9 or 2400 CAS 10 for within $5 of those 1866
http://pcpartpicker.com/part/gskill-memory-f32133c9d8gxl
http://pcpartpicker.com/part/gskill-memory-f32400c10d8gtx
Add a SSHD to speed up game loading ... 2 TB model id $25 more
http://pcpartpicker.com/part/seagate-internal-hard-drive-st1000dx001
If you find your build cost breaking $850, I'd consider an Intel 4690k / Z97 based build
