I recently got a 21.5" 1080p monitor and i decided i would use my old 19" Tv and this monitor as a duel monitor setup. I already have the cords ordered for what I need to do so. My question is, will my computer be able to run (safely) because I have this Kentek 750w power supply that I know isn't good quality, but has worked flawlessly for about 6 months now. I have read how this PSU can only provide about 500w of power and i have done some PSU calculators with my rig and they all fluctuate from around like 200-300-400w needed.
My Rig
AMD FX-6300
XFX AMD Radeon R7 250x
1x8GB DDR3 Ram
Gigabyte AM3+ 78LMT USB3.0 Board
1x7200rpm WD 320GB 3.5" HDD
"750w" Kentek PSU
No Disk Drives of any type.
I plan to use my 1080p monitor for everything but then my 720p TV for my games like CSGO, Minecraft, and eventually I want to get high end games like GTAV (720p doesnt bother me so i figured it would be easier to run games on that then)
I also Plan On buying another 1TB 3.5" 7200rpm HDD soon.
I've been looking into getting a better quality 550-600w PSU but I do not want to spend $50+ right now.
So here are my Questions now that you know all my info
1. Do you think I should upgrade my PSU or should my cheap one be fine for my rig, I do not want to lose any other components if it fries.
2.Will my PC Be able to Handle my duel monitor setup situation without issues ?
3. Once I do decide to buy my second HDD how will that work, do i just plug it in via SATA cable and boot up PC and there it is?
4. If my Computer/HDD with OS were to "crash" and not boot up again and i would need to buy new components, would i have to buy a new OS? Because I do not want to spend 100$ on Windows 10 if it were to happen. (And how could i prevent this from happening, OS only on 320GB Drive?)
Again, I do not want to buy a new PSU unless I have to, i know i will if i upgrade my GPU for sure but I just want to feel "safe". I spent a lot of money on this and i do not want to lose it.
Any further questions, Please Ask! Thanks
My Rig
AMD FX-6300
1x8GB DDR3 Ram
"750w" Kentek PSU
